I am trying to add a remote resource with a directory of videos and it does not seem to work. I have a YouTube remote resource that works and displays a folder icon but the remote directory shows a different icon. When I drag the warehoused video resource into a gallery, the preview displays “Drag & Drop a folder of resources” in the gallery component preview. I have tried using both the relative directory and the fully qualified location as the URL for the resource and neither works. I pointed my web browser to the URL of one of the videos and that worked fine so I know the location is valid. My workaround is to add those videos to my YouTube content and create a playlist for those videos but I don’t want that as the final solution because these are old videos that I do not want at the top of my YouTube content and I have not found a way to force them to the bottom. Has anybody else have these issues?
Also It would be nice to be able to edit the remote resource URL after it has been created.
PS: I tried to include an image showing the resources tab in elements but it would not allow me to post with an image included.
Yes I specified the remote folder as the full URL. I read in the documentation that the remote folder only worked for images not videos which is why I tried to create a remote resource under the Resources tab (see below). That also did not work. I also re-checked the URL to one of the warehoused videos and the video played in the browser so I know the directory URL is correct.
If I understand this correctly, you created a remote resource and set the URL as a folder, e.g. https://you-website.com/path/to/folder?
If so, that’s not going to work. You can enter a remote folder URL via the Gallery settings. Select the Gallery, then go to the properties panel, then click on the Media group and set the Source to “Remote Folder”.
At the moment the Gallery component will only work with remote images, videos are not supported. However, the good news is that we have an update coming soon that will add remote video support to the Gallery
