After renaming a global, it seems that the new name isn’t saved. Evertytime I leave the components pane after renaming, next time I open the pane again the original name from the global is given.
You can rename globals in the Components list, just right-click and rename.
You might have been trying to rename it in the Custom Components slideup inspector (this shouldn’t be visible or editable for Globals) — We have some UI fine tuning to do there!
I did that but the name gets lost everytime. I can’t upload a screenmovie. But this is what I do:
- Renaming like you showed in the screencast
- I go the the page layout with all the used elements
- When I go back to grap the global, the given name is lost.
Could you seen a screen recording (and project) via email?
Got your video… can you try pressing return when you’ve renamed it? (instead of clicking out of the text field)
That’s the trick ![]()
Perfect, we’ll get it properly fixed during the beta cycle ![]()
