Reveal possible issue or expected
@dan can you replicate this
ok spent a little while trying to understand why my Reveal wasn’t working as expected. This only happens if there nothing above the reveal. Thought it was mt components first but repeats for me on a blank page, see video below
https://share.cleanshot.com/zVbHCYCKZR0XGjKGhGbW
there is an upside, it would be good to have this option :rofl:
so for me it needs a height of min 0.5px on the page before Reveal (first Reveal on a page) works for me
so if I want to place a reveal in the menu, this would normally be the first thing on the page, it works in the odd path, as soon as an element is placed above the menu with a height the reveal works
@dan is this normal behaviour, no answer so far. Unless there is a component with height before the first instance of the reveal that first reveal works backwards. I have tried multi combinations, I am creating a menu with a specific reveal combination (not the moon and sun, just practice), the first reveal will operate backwards unless a component with height is not inserted above.
See video below
ok still no answer to my question see video showing my issue (is this expected behaviour), and please could someone test my project to check if they have the same issue
first page is a menu in a reveal with a container and some text below, the reveal is set to slide down, but it slides up
the second page is exactly the same, except I added a divider above the menu to add height before a first reveal, it now works as expected with the reveal causing the menu to slide down
thanks in advance
video showing above
project file
elementsapp://downloadDocument/rw6R2b8FTGPp
that looks like a bug! I’ll add it to the bug list — we’ll take a look at this one ASAP :slight_smile:
@ben not sure if this is expected, when the menu is in a reveal the page names do not update if changed, unless the menu is removed from the reveal
That looks like a preview caching issue, we’ll take a look asap! :slight_smile:
