RW Classic 9.6.8, third photo on blog entry doesn't appear in simulator mode
Yes, I own Elements, however since I need a blog for my webpage, and don’t have the time right now to learn how to do it exactly the way that I want, I’m still using RW Classic (9.6.8) to publish. Editing this morning, midway through creating an entry with photos, I found that only the first two photos I’d added to the page appear when I switch from edit to simulator mode (clicked the “eyeball” on the top.). The text appears just fine, as well as the first two photos, but the next ones that I tried to add just don’t appear.
What am I missing??
You might want to check they are in the right format, and have the correct file name/extension.
Thanks Dan. I’m not sure that was it, but I tried deleting them entirely, then re-added them (resizing as needed, and now it’s working fine, so something, maybe that did it.)
Glad it’s now working for you :+1:
