I just added some new content to my RW site. I did not add anything other than I always do… but suddenly RW starts behaving strange by auto saving files in a weird way… and it keeps on crashing,.
Please refer to attached screenshot.
I’ve not seen this issue before; it sounds very strange.
I’d recommend quitting RapidWeaver and moving your active projects to a new folder to work from there. You can then delete the folder containing all the random files.
You might also want to try running First Aid on your disk using the Disk Utility app.
When I save the project into a folder, the same thing happens plus I get these strange folders and files
Funny enough, this only happens with this project and this folder, not with any other….?
I think I use the latest version of Stacks. Where can I find out about that?
Where would you ike me the project file to? Do you need the full project or only the front page?
I wait and see what you say before contacting your head
Thanks a lot
It is going from bad to worse……
After receiving the message that I need to up-grade Stack, I did so to Stacks 5, paid the fee and got and Email with the details.
However, after installing it, I now still can’t use Stack at all. Instead, I get these messages…….
What can I do about this mess? The developer does not seem to be very happy about RW, judging from his message which popped up and which I attach herewith as pdf it sounds like is no more Stacks?.
Hope you can help me sort out this to work or at least get the 29.95 USD back for a not working Stacks….
Thank you
Cheers
Hucky
(Attachment Stacks4Stacks & ThemeFlood have closed.pdf is missing)
Thank you
Cheers
Hucky
Attachments: seems like the attachments have been rejected…? As reported by an Email
