At the present moment I have 42 pages including sub pages in my project.
I am using RW6, Foundation, TCMS, and Sitelok.
For publishing I use Cyberduck via FTP.
My problem is that when make a total export (Shift + Alt + Cmd + E) it takes hours to export, even if the only change I have made is to duplicate a page. And when I export a single page (Right click the page and choose Export Page) it takes up to 15 minutes to export this single page.
I am working on a MacBook Pro with 8 MB RAM and lots of diskspace.
Am I doing something wrong, or is there something I can do to improve this poor performance
Even 442 pages shouldn’t take more than a few minutes - actually to export… from your RW project into your designated Export directory alongside it; that’s what you mean, isn’t it?
@peterkroman My guess is your project file is pretty darn big. I typically make websites that are around 40 pages long (for courses) and they typically come in around 13-15 Mb. My guess is you are using Resources a fair amount for images/video/audio. Or, if not, then something is definitely amiss.
It seems that RW7 will handle resources much better. Have you considered warehousing some of your images? (BTW, I don’t know the cause of the size so that may not be the problem.)
I am warehousing most of my pics. I don’t have any videos, and I don’t have any audio on the site.
I have some pdf files in pdf embed, but they are basically warehoused as well
I don’t know what is going wrong here. But I have another problem which might have something to do with it. As mentioned I am using TCMS on selected pages, and after I started with that the Preview is showing a h… of a lot of code, and absolutely no preview. Se the attached.
Don’t know if there could be a connection there?
Example of Preview of a page without TCMS:
Example of preview of a content page with TCMS (this screen shot is taken a little further down the page, and the funny thing is that I don’t have any videos in this site at all):
@peterkroman I have no idea what is happening in your case. It seems like you don’t use, or you warehouse, media that would account for a lot of the size of your project. My guess is TCMS may be adding a lot of size to your project file. I don’t use it: and it may be completely normal that it adds this additional size. I simply don’t know.
The preview showing all the code can happen if there’s a lot of PHP which is likely in this case. How does it all look when published: that’s the bottom line.
You may want to contact Joe about this. I’m not sure the problem is related to TCMS, but it’s at least useful to eliminate possible causes.
When doing so, please archive the project file and put to dropbox or other sharing service and send the support emails the link not the actual project file as most of them don’t accept over 1mb data files…
