hmm if updates is working may want to change this message as it says error,
will give that a go
No, no software monitoring or blocking. Will download again.
Non on my system either
Downloading it again worked. Yay, the external browser preview is working, as are custom fonts! ![]()
Just did update browser preview works a treat
Is there any possibility the Safari (browser) preview will include auto/live-refresh when changes are made within Elements? Having to constantly refresh the browser will get old fast.
rather than a video this is still an issue, I dropped in a container then dropped in the paragraph, at this point you can seen the container tag and paragraph. drop in a section and a paragraph in that section. you can see section and paragraph tags, but switch back to the container and only paragraph is visible or selectable
It’s REALLy hard to see what the issue is without seeing a video of this in action. If you did record a video you could try sending it to me via email (YouTube, FTP server, or WeTransfer would also work).
However, I’m wondering if this is just a side effect of the way we handle selection.
The dark blue selection is the Selected Component, while the light blue section is the Component your mouse is hovering over. As our editor is WYSIWYG sometimes components can be sitting on top of each other making selection awkward.
There’s many ways to help select the component you’re after, take a look at this video… hopefully that helps…
dan no probs I can easily select different ways, but strange the first time you drop in a container, drop in a paragraph you can see both, as soon as you drop any thing else into the page and click on second drop in the issue appears on the container/paragraph.
you should easily be able to replicate
drop in container
drop paragraph into container above
move cursor in and out of container
you will see as in your video both highlight
now drop in a section below the container
drop paragraph into section
select paragraph in section
now switch to first container
I only see paragraph, no container
not an issue for me , able to select other ways, might slightly confuse brand new users
