When I will close my Element (b19) it kept telling me to save.
Thanks for the report, do you always see this or is the issue intermittent?
@dan Yes it is kind of intermittent. When I close with X the program tells me to Save (also if I have save in the Menu). And When I Save again it sometime repeat, but often I got ‘the Ball’ and then it close with the changes saved.
@dan The Save-problem has gone from bad to worse with b20.
It takes at minimum some seconds to save and close and often Element freeze when I click the X-close and it play the ‘ball’.
Once I got this ?
And generally I have problem when I try to use Images.
Sorry you’re having issues, and don’t worry. We are aware of these issue and will get it all fixed up!
