Can you make the left column in Elements have a fixed height with a background image, while the text or other content in that column can still scroll?
Yes, this is possible in Elements, most things are when you know how ![]()
I’ve recorded a quick video showing the changes I made to the content column and have posted a link to the project below!
Open Scroller Project in Elements
Let me know if you have any questions ![]()
Hi @dan I need to bother you again regarding the scrollable area. This time we want to let the images and the content below (like text and graphs) on the right side scrollable, and the title on the left side be sticky as long as the right content scrolls. I rebuild everything like you showed above and also found another tutorial here in the forum. It works as you showed me pefectly, but only with images that keep sticky. Not text. Is there somethig to consider?
Thanl you upfront.
