thanks for the upate. Tried the collection in the globals and that works. The scrollbar still having the same issue. But maybe something is wrong on my side? I will throw up a short video and upload a sample app.
Same one. But right now the bottom scrollbar should not show up when there is a width. I never got that issue with a manual created webpage. But lets say it like that, in the Browser that does not really matter. I guess the problem is more that when using Elements and you click on “md” you want to see “md” and the changes applied. So far I see 2 issues:
The bottom scrollbar shows up now (did not have that before, Browser + Elements)
Selecting a size does not reflect that in Elements
Do you want to have a call maybe so we can check that out?
so I did try that with the unplug the mouse and that works, can see the unplug at 0:11. Then later in the video you can see there is a horizontal scrolling, but the root cause of that is the Standard Navigation. After removing that one the horizontal scrolling is done.
So I would assume its just component related. Anyway, all good Thanks for the help.
