Select element value
I am using the new SELECT element. How do I enable the “Value” field to link to another page in the website when a “Label” is selected?
The “Select” is a Form component and is for sending values via a form, not for creating a drop down menu with links.
If you wanted a dropdown menu you could create one using the other build-in components, here I’m using a “Dropdown” Component with some buttons in it so you can style it however you like!
:backhand_index_pointing_right: Open Project in Elements
Hopefully this does what you need :slight_smile:
Dan,
Thanks!!! I will build it as you suggest. Great response!
