I would like to know how SEO is managed in Element?
Do you plan to integrate like Yoast for WordPress, which is performant?
Thanks.
Thanks.
In Elements, you have access to all the common metadata options you need for SEO.
You can set the HTML tag on sections (div, span, header, article, section, etc) and tag values on text (P, H1, H2, H3, etc), along with alt text for images.
Elements also automatically produces an XML sitemap, and we have a dedicated metadata panel that allows you to set metadata on a per-page basis, including some common open-graph tags.
And if that wasn’t enough, you also have access to the raw HTML template for your site should you want to add anything that’s not supported in the UI.
Is there anything else you needed?
Note: a little more information on Elements and SEO is available in our work-in-progress manual.
