Sequoia and RW 9.1 - No local folders for publishing
am still on RW 9.1.1 , installed Sequoia 15.0.1 and now I can’t publish to a local folder - at least with one project …
when trying to reestablish the settings in publish it just does not save the path to the chosen folder.
Any ideas how to solve this? A workaround?
(Please don’t tell me to upgrade to 9.3 )
Thanks for any input.
Tom
Is local publishing working with other projects?
Are the permissions on that local folder and project file correct? Try adjusting them if not Change permissions for files, folders, or disks on Mac - Apple Support
Maybe try creating a new folder on your Mac and changing the path to that new folder to see if it sticks.
9.3 brings official support to Sequoia. Might be a good idea to upgrade to it if you want to ensure compatibility going forward. There’s a 25% coupon code for the rest of October if you want to save some money on the upgrade.
Hi Dan,
thanks for answering. I checked the permissions, all was good.
Then - the good old simple measure - restarted everything.
Now I am back for good, everything is working again as expected.
Thanks for the hint to the promo in October.
