I’ve been using the SetApp version of RW which is version 9.2. With RW no longer in SetApp, how do I upgrade to Realmacs latest version 9.43?
You’d need to purchase a license via our online store and then download the latest version here to replace the SetApp version.
Hope that helps!
Is there any discount for having the SetApp version, or for having the last version I updated to from Realmac, version 7?
If you enter the following coupon code at checkout you can save 25% on RapidWeaver Classic: CLASSIC25
Thanks for your support!
