Setting page links
How do I get pages to link with their name in menu?
It’s unclear what you’re asking here. If you create the menus using the built-in menu Components, that’s done automatically. If you’re building some form of menu yourself, you use the Inspector to link each menu item to a page.
Elements is so complex that I am frequently unsure a to what I have done, having tried several options. Whatever I did, I have 5 pages, and none show in the header menu, so I assume there is no link.
I also can not get Grid to give me side by side boxes for image and for text. I followed your suggestions for columns and rows, but the yext still appears above the image. Maybe it has to do with photo size. When I attempt to adjust image size, it does not change physical size, but only the resolution.
You can check (or uncheck) the visibility of pages with just one click.
In Grid set “Grid Alignment” to Colum. Then it should work
