'm using the Share Launch stack inside CleanMenu, which is wrapped by Chroma Pro, on my RapidWeaver site. On macOS and iPad, the share icons work as expected, but on iPhone 16 (both portrait and landscape), tapping does nothing.
The icons work flawlessly when the Share Launch is placed outside the menu. I’ve tried basic z-index CSS adjustments, but the issue persists when it’s nested inside the CleanMenu/Chroma setup.
Could you advise whether this is a known layering issue or suggest a simple fix? I prefer to keep Share Launch inside the menu for design reasons.
Try clearing your browser cache - it might be that your phone is still showing and older version of the site if you visit it.
On an unrelated note: your menu is extremely heavy - it takes my phone a couple of seconds to load the menu after it has loaded the rest of the site (and I’m on a 200 mbps wifi network). Google will rank your site lower because of this, and it might confuse your visitors as the menu doesn’t show up until they’ve been on your site for a while.
Thanks for checking this out. I deleted the Share it stack and replaced it with a Limelight Launcer stack. That is why what you tried actually worked on your iphone. I know I need to compress a lot of the images and hope that will speed things up.
