I am trying to use shared code. But did it not get it to run.
Will take a look shortly… just trying to get today’s new build shipped!
Hi @Beblebroks,
Please hold off on using the shared hooks as we are may, unfortunately, need to remove this feature from the dev packs!
I’ll update you as we make a decision on this.
Thanks!
Hi @ben,
all good. Was just playing. I found another solution. I just add the function directly into the hook.js file.
Thanks!
Awesome! ![]()
