Shift-CMD-K Uploading won't work?
Is it possible that the Shift-CMD-K upload is no longer working even though pages are shown as modified? I changed something in a global folder that is used on every page. All pages are correctly displayed as modified, but Shift-CMD-K displays a preparation window and the actual upload window never appears.
Alt-CMD-K works perfectly, and over 3,000 files are transferred in just a few seconds.
Similar problem when I click on the Publish button. Only works when I click on Re-Publish All Files. @ben
:smiley:
Never pressed this button - i’m a keyboard guy
We’re about to do another release, and this should be fixed in that new build — Stay tuned!
@Ulrich and @PLM, give the new build a while and see if that helps…
Thanks. It’s fixed.
