Simple CMS - Live Example
So, I have used Classic as the CMS Admin Control (EasyCMS JW), and Elements as the receiver. The CMS changes are affecting the Classic Admin page only. Then, Elements is looking for the warehoused images on that Classic page. The result is any image placed on the Classic Page will appear on the Elements page.
As I’m using Hostinger as a Host (CDN), It takes longer for the Cashed images to make the transfer. Using the ole right-click-reload on the Elements page will immediately change the image used for the transfer.
The Classic URL is: ā€œhttps://project124.good-nrg.co/admin/ā€
The temporary password is 4532 (Please, no shenanigans)
The Elements URL is: ā€œhttps://project125.good-nrg.co/ā€
Open the Classic Admin URL and select any Image that you wish to transfer to the Elements side. For now, use a jpg (it can be set to use others, but not for this example). After dropping it, it should immediately make the transfer. If not, right-click-reload the Elements page.
Simplicity. This is not designed to replace the up and coming CMS for Elements, but it will take quite some time to get that working well. This trick will work until then.
