How do I create more padding between the “top pages” links in SIMPLE FOOTER? I’ve been digging around for an hour and can’t find a tutorial/suggestion.
Thanks!
Hi @D03ree
With the Top Pages component selected, you can use the Gap setting to add more space between the links, hope that helps ![]()
