Sitemap.xml : double slash in urls
RapidWeaver Elements 0.7.2 (23433)
I have verified the sitemap.xml file once published and I observe that the urls have two slashes for each page, like that:
<loc>https://abzzz.abourdon.fr//index.php</loc>
or
<loc>https://abzzz.abourdon.fr//page/index.php</loc>
Are you aware of that?
Thanks for reporting this @annebourdon, I’ve added a ticket for it and will get it fixed up soon.
Cheers!
@tpbradley
is it possible to dispense with the index.php/index.html at the end of the sitemap in future? And only use the canonical URL or the url+path?
otherwise there are always error messages in the google search console.
Yes, should be able to do that. I’ll add it to the ticket!
wonderful. thank you!
maybe also a small ticket for rw-classic? :squinting_face_with_tongue: :melting_face: :smiling_face_with_three_hearts:
so that this is also adapted there at some point in a future update?
Yep, that shouldn’t be a problem. I’m fairly certain the code for the sitemap is still shared between the two apps.
