Soft hyphen on long words?
Is it possible to make a soft hyphen in Elements? I want to use it for mobile viewers.
I tried “Shift + Cmd + -” on accommodation, but it doesn’t work (accom-modation).
?? HTML
?? U+00AD
@dan
On the block of text in Elements you can add [hyphens:auto] to the CSS Classes field under Advanced, that will solve this for you :slight_smile:
