is it not possible to set margins individually, might be doing something wrong
is there emo longer drop down for padding
You are not seeing the padding dropdown because you have the theme option turned OFF. If you click on the little icon in the top/right corner you will get the default dropdown when you click on the padding values. You have the theme settings turned ON for the margins but OFF for the padding.
Thanks I’ll try later
Click the blue dotted line in the middle to link/unlink them…
I find those lines barely visible when using Elements in Darkmode.
Thanks for the feedback, we are planning on improving the controls and will look at making them more visible/obvious.
