I am trying to get Squash to rename images in sequence. See screen shot. It will name the first file camp-## and then keep overwriting that file even if overwrite files is not selected in the export settings. So basically it just keeps the one file overwriting each time. It should rename all to camp-01, camp-02, etc… Can you help? It does not appear to be working as intended to me.
I think I figured it out. You have to use ### or it will not work at all. So my output must be camp-000, camp-001, etc…
Yes, that’s correct!
