Good day~ I am a not a tech person, just use RW for my website. Lately, I have had issue with Stacks from YourHead whereas images keep delinking from entire sections of my site. Curious if there is an alternative Stacks app so I can add elements (sry if this is not the correct term, want to deliniate btwn a Stack page and an added stack element). I like Stacks5 and have inquiries out to YourHead, just want to be expand my knowledge for what else is out there. Appreciate your insights. Cheers
Hi @mzscapes,
The people behind RapidWeaver are working on a new product called Elements that will allow you to design your websites in a similar way that Stacks does. It’s not available yet, but will be soon.
As for the delinking problem: this is a bug in Stacks that, to my knowledge, has been solved in the current version. Check if you have the current version of Stacks, and update or upgrade if you don’t have it.
Erwin
Ahem, it is available now in early access… https://elementsapp.io
Better get that cough looked at @dan ![]()
But yes - thanks for the addition ![]()
haha, seems to be happening a lot of late ![]()
