Stacks Bug: Images links disappear
Good day~ I use Rw9.4 and have troubles with images de-linking on a random basis. For most image galleries I use Montage 2 and drop the image files from subfolders within the RW project. While I was working on one section, I noticed de-links in another section doing random checks. And even then, sub-pages with the section have some pages de-linikned and others show the the expected image. My site is heavy on images, so no easy task to re-link.
This is the third time occurring. I am on the road right now, so do not have access to timemachine to do a rollback!
Any ideas on what is causing this issue and solutions? Appreciate any help & direction you can provide. Driving me crazy!
Hi @mzscapes,
What version of Stacks are you on?
Images (and other resources) delinking was an issue with Stacks a few subversions back, but as far as I know, this has been resolved in Stacks 5.xx.
Erwin
Thanks Erwin~. I am using v5.3.0. Is there a possibility that Montage 2 is wonky and causing the delink? Did not see anything searching on Montage 2.
Any ideas on how to proceed. Cheers
I checked with Doobox on Montage 2, and they advised most likely Stacks5 is the issue. Moving on to Yourhead for assistance. Thanks once again for answering.
Cheers
Hi @mzscapes,
Sorry for the delay.
Hmmm… 5.3.0 shouldn’t have this bug. Perhaps it’s back. Best to contact Yourhead indeed.
Erwin
Thanks Erwin~
I have raised the issue with YourHead, waiting on their response. Appreciate the info.
Cheers..
mark zborowski
May our paths and errands meet - JRR Tolkien
The power of imagination makes us infinite - John Muir
There is nothing worse than a sharp image of a fuzzy concept - Ansel Adams
Hi Erwin~ As an update, I was able to roll back and recover the galleries with missing image links. No response from YourHead so far, so hope the latest version of RW & Stacks have fixed the problem. Cheers
Hi @mzscapes,
Good to hear you found a workaround.
Don’t count on a fix from RapidWeaver/Realmac though, as linking images in stacks image containers is purely a Stacks function. So the fix really needs to come from Yourhead.
Erwin
Thanks Erwin~
Well, YourHead has been unresponsive after several pings. Not sure what else I can do. Guess will have to take a look at Elements, but do not relish having to rebuild all my pages!
Heading over to ping them again.
Cheers..
mark zborowski
