Standard menu for mobile
Dear Elements team,
In the Standard Menu component, is there a way to manage menu items in the Mobile menu separately from the desktop menu? i.e., position, items order, font size, background, etc…
Not currently, but we do plan to introduce other more flexible menu components down the line.
Dear Dan,
I am still facing an issue with the placement of the close trigger in the mobile menu. In my case, RTL menu i.e. Arabic, the close trigger will appeqar om the right side of the menu covered by the menu text. Is there a way to change the placement of the close trigger?
Thank you
I hope the ‘flexible menu component’ can help me create a bilingual website, for instance, with two menus for two different sets of web pages. Thanks.
That sounds like a bug, I’ll get it added to the list :slight_smile:
