I tried to put a logo on the standard menu using the drop zone but it did not work. Now I have some code on all the published pages that I can’t get rid of. I tried undo but that didn’t work either. I s=did try adding the logo via resources but no joy there either. I see that other people can get this to work, so please let me know what I am doing wrong.
Unfortunately I can’t seem to make the SVG on the standard menu work, even with an actual .svg file. Any time I try it, it does not display and adds lines of code to the top and bottom of the page.
Are you first placing an SVG component in the drop zone in the menu? Once you have an SVG component in there, then you can drop an SVG file into it.
The logo in the menu is just a drop zone, which means in order to place an SVG or image in there, you first need to add the appropriate component for the file type you plan to use, in this case an SVG.
Here is a link to the site: https://trainingdogswithlaura.online. The home page and the members page I tried to put the SVG in the drop zone and those are the pages with the lines of code above and below the standard menu.
Sitelok is not the problem since the membership part works fine. It was just when I wanted to add the SVG to the drop zone is when I got this code displayed along with the page.
