Strange Behavior with a Global Footer
@dan I have a global footer setup on one of my projects and for some reason, it does not respond to clicks in the editor. I can select components in the footer from the node browser, but the minute I click in the footer in the editor the selection is lost.
This means I cannot edit any text in the footer as I cannot double-click on any text component.
The strange thing is I’m using the same footer on another site where it works just fine.
I wanted to report this before I tried rebuilding the footer in the hopes of fixing the problem. The footer works just fine in the browser, just not editable in Elements. Even hovering over the footer does not show any of the component labels and borders. Very weird.
I’ll hold off fixing it in case you want to look at the project.
