Fatal error : Uncaught Error: Failed opening required ‘/Users/michaeldroste/Library/Containers/com.realmacsoftware.rapidweaverelements/Data/tmp/RapidWeaver/84283/RWDocumentPagePreview/document-3FB8CDB8-9C53-4866-8890-462F451A7E9D/../rw/elements/com.realmac.corepack/api/vendor/autoload.php’ (include_path=‘.:’) in /Users/michaeldroste/Library/Containers/com.realmacsoftware.rapidweaverelements/Data/tmp/RapidWeaver/84283/RWDocumentPagePreview/document-3FB8CDB8-9C53-4866-8890-462F451A7E9D/song.php:4 Stack trace: #0 /Applications/RapidWeaver Elements.app/Contents/Resources/RWWebServerLaunch.php(189): include() #1 {main} thrown in /Users/michaeldroste/Library/Containers/com.realmacsoftware.rapidweaverelements/Data/tmp/RapidWeaver/84283/RWDocumentPagePreview/document-3FB8CDB8-9C53-4866-8890-462F451A7E9D/song.php on line 4
Thank you SOOOO Much!
After 1 week of debugging - FINALLY WORKING!!!
Very happy!
Now trying to bring it to life…
No problem, always ask on the forum and we’ll help you out ![]()
Well - thought it was working…
elementsapp://downloadDocument/Gwpu3qyEYmva
Every time - no matter what song you select - it goes to the first song only…
just put one song in to test the system…
or are you saying it pulls the same data from the same md file
nothing is working ![]()
added 10 songs to make sure…
changed CMS
changed audio code
relinked file paths
elementsapp://downloadDocument/GicB290sNzUZ
Cleaned up audio - cleaned up meta data
elementsapp://downloadDocument/devOokQZnx18
Still not seeing individual songs (and the songs are not playing)
tried renaming parts other than ‘songs’ or ‘song’
still only going to the first mark down entry
elementsapp://downloadDocument/KvhBaZDG9bnH
Very frustrating… been working on this non stop
Started blank pages twice - doesn’t work
Don’t know if it’s me / some little switch/ some naming problems or what…
Giving up for now - need to step away from this - giving me a headache ![]()
