Strange Problems with Grids in b20
I’m seeing strange problems with some of my grids after upgrading to b20. The example shown below is how it looks in the Elements editor. This works perfectly across all breakpoints and did work in Safari before upgrading to b20.
After the upgrade this is what is displayed in Safari when previewing the page. Something is clearly whacky and I have tried every possible combination to try and fix it but nothing seems to be working.
Hopefully, someone can shed some light on what might be going wrong here or if something changed in b20 to cause this issue.
Have you tried to rebuild that grid?
No, I have not tried that yet, but will give it a try next.
OK, I rebuilt the grid from scratch and that seemed to fix the problem, very strange. I guess something was off somewhere that I could not spot.
Anyway now everything is behaving as it did before upgrading to b20.
Thanks for the suggestion.
