How can I impletment a empty structure element in my pages?
like here!
like here!
Use a folder not a page
It’s an empty structure element in the layout view not in the page view! In the layout view you can´t use a folder!
Yes, like this!
I just created dropzones, might be easier in version 2, is there a reason why you need this
To get a clear structure! It helps me for a better overview!
I know what you mean — that’s actually something I really miss in RW Elements.
RW Classic handled that a lot better, unfortunately… but that’s life.
Not sure I’m following here… Classic/Stacks doesn’t even have a node view ![]()
sorry… that’s my fault. I think I only read it with half an eye and thought we talking about something else.
That’s it what I need. But I can´t copy any object in the layout section.
You can rename items in the node tree, so perhaps this will help, so “Container” could be renamed to “Header Area” for example.
Alternatively, you could create a custom component that could act as a “folder” to organise your components. However I would not recommend doing this, you’re better off keeping the component tree as it is imho.
