Songs 1-100 (color coded red)
Songs 101-200 (color coded blue)
Songs 201-300 (color coded green)
Songs 301-365 color coded gray)
Can I have four ‘blogs’ all accessing the same CMS?
How do I do this?
You can have as many Collection components pulling from the same CMS data as you like. So yes, four blogs from the same source will work fine.
The only limitation is pagination: the Collection can’t currently offset the starting point, so you can’t fetch “items 200–300” automatically. To split your content into fixed 100-item ranges, we’d need to add an offset setting to the Collection component, which is something we could look at adding in the future!
Hope that helps ![]()
