Stupid Question 🙋‍♂️ Marquee Animation
I know this works on my wife’s iPhone - so it does work in mobile…
Won’t work on mine…
Why?
Been playing with settings for 2 days - turning on / off options - deleting caches - turning on / off content blockers - nothing seems to work…
So my question…
Maybe if I knew how Marquee was programmed - perhaps I could try to turn off the offending blocker?
That’s my train of thought - maybe thinking incorrectly… trying to brainstorm the problem…
Any ideas?
It would be nice to see the Marquee on my iPhone :slight_smile:
Thanx
Mike
I don’t think this is an Elements or Marquee issue. It’s Safari extensions interfering with animation scripts. The screenshot shows multiple blockers active at once, which explains why it works on one iPhone and not the other.
If you share the URL for the page I can test it here on my iPhone for you…
another thing that will stop the Marquee from animating on iPhone is if you have “Reduced Motion” turned on in the accessibility settings!
works on my iPhone trumpetstudio.com
@ben @dan
No not a marquee issue - at all - ever
It was some setting on my iPhone - not questioning the product… :slight_smile:
Ben hits it out of the park!!’ Home Run
Went into accessibility - yep :+1: reduced motion was on - turned it off
It’s Working!!!
Thanx
Nice to see the animation on my iPhone now!!!
Thanx again!!’
Ah perfect, glad you got it working :raising_hands:
Thanks for the tip, that issue was driving me mad !!!
