jbob
(jol yates)
September 17, 2025, 9:00pm
1
Am wondering what the correct structure would be for a shop where you might want 4 product items side-by-side on a big screen and only one on a phone.
Is it a grid which changes the number of columns based on the format ?
How then is the ‘overflow’ achieved when the grid width is reduced, but the length must be extended (ie. from 4 products across to 3 when you have say 16 total).
Do I set it up as a grid of 16 wide by one high and adjust from there according to required format ?
Sorry it that’s a daft question
Jol
sbchasin
(Steve C.)
September 17, 2025, 9:17pm
2
The grid has 12 columns, so I would do 8x2 or 4x4 on large screens. When you put it together in Elements, figure out how you want it laid out first, then design mobile first (as that is how Elements is designed). It will be w WHOLE lot easier that way.
ben
(Ben)
September 18, 2025, 6:31am
4
Hi @jbob
A Grid sounds like the correct component for this
Steve’s video above shows him setting up a responsive grid, but if you need more information on responsive settings, you can check out the video here .
If you get stuck just let us know and we’ll be happy to help
jbob
(jol yates)
September 18, 2025, 8:20am
5
Thanks Steve and thanks Ben - exactly what I needed !!
jbob
(jol yates)
September 18, 2025, 9:26am
6
Steve, Ben
A grid may be defined as big as 12 x 12, right ?
That means that a grid can have 144 products (for example)
Mine has 3 across by 10 high … grand total 30 products - for a desktop screen
However, when I define for a cell phone at 1 product across … I am limited into 12 rows (following me?)
Meaning I can now only have 12 products, right ?
This can’t be right - can it ?
I think the use of a slider here is fantastic - but isn’t it artificially limiting my grid to 12 x 12 ?
I actually want 1 across by 30 down for mobiles - in this case (some may want more).
Thanks, Jol
jbob
(jol yates)
September 18, 2025, 9:30am
7
Further - with my 30 product (3x10) …
… if I adjust for mobile at 1 product across
then they start overwriting themselves
upssjw
(Steve W)
September 18, 2025, 9:39am
8
@jbob
this is working with the max of 12 cols, but this is using auto row not defining a grid in number of rows, see how many rows here
upssjw
(Steve W)
September 18, 2025, 9:50am
9
How did you build your single container, need to make that responsive as well
jbob
(jol yates)
September 18, 2025, 9:51am
10
Thank you Steve - great explanation
upssjw
(Steve W)
September 18, 2025, 9:52am
11
Could you show before you reduced to mobile view what does that look like, I was using images they scale automatically other content may not do that
jbob
(jol yates)
September 18, 2025, 9:54am
12
Nope - really happy here Steve - you’ve been an enormous help !!
I’d love to show you
However I cant upload it as the page just shows this ..
jbob
(jol yates)
September 18, 2025, 9:55am
13
If I export to my local drive and preview the print_shop.html by pressing the keyboard space bar … it shows the same … so somehow it looks fine in RWE but crappola once exported from RWE
jbob
(jol yates)
September 18, 2025, 9:56am
14
I started another thread about it here
Dan - I’ve tried what I can. If I ‘export site’ to a folder on my hard drive … and preview my questionable files (eg: print_shop.html) … then all necessary files should be available. They are clearly not as I get this empty image block and nothing else. FTP’ing files to the server at (…/2025) confirms this. (ie ../2025/print_shop.html)
Additionally (and there may be a clue here) - The header (a global) is missing its lower (4 part) image on all but the index.html page. [This image was added to …
upssjw
(Steve W)
September 18, 2025, 10:04am
15
I mean in Elements, snapshot and just post here, copy and paste
jbob
(jol yates)
September 18, 2025, 10:56am
17
I’m pretty happy with progress Steve - thanks to you !!
(although as you see in the next image I still have big spaces between rows
jbob
(jol yates)
September 18, 2025, 10:57am
18
My bigger problem now is that although it looks great on my screen - the export / and / or upload results in this big black empty box
jbob
(jol yates)
September 18, 2025, 11:00am
19
I think it’s an error with globals ? - as only my initial page ( Peter Yates, Artist and Architect 1920-1982 ) displays the full header
upssjw
(Steve W)
September 18, 2025, 11:10am
20
I use show outlines to check position etc
