Success message not showing for contact form
I have tested contact form several times with steady success in receiving entry data by email message.
Problem is that I cannot get “success” message to show. Please join in if you have any suggestions for getting it to work.
my component nesting is: form holds a flex, and flex holds input input select input success error submit
live page url is Valuable Work
recent log lines are:
[2026-02-16T19:25:59.105343+00:00] form_config.INFO: Email sent successfully {“config_path”:“/home/u229127035/domains/valuablework.com/public_html/backend/rw0586AFDA_D4F8_4D8C_B3D3_360094277A69/config.php”,“to”:"jmacnab@valuablework.com",“subject”:“VW website inquiry”,“attachments_count”:0} []
[2026-02-16T19:25:59.105489+00:00] form_config.INFO: Email sending attempt {“config_path”:“/home/u229127035/domains/valuablework.com/public_html/backend/rw0586AFDA_D4F8_4D8C_B3D3_360094277A69/config.php”,“success”:true,“to”:"jmacnab@valuablework.com",“subject”:“VW website inquiry”,“form_data_fields”:[“name”,“email”,“select-rw2DF0813B_B3EC_45E7_8BC6_137D6795F247”,“message”,“_metadata”]} []
[2026-02-16T19:25:59.105528+00:00] form_config.INFO: Email form submission completed successfully {“config_path”:“/home/u229127035/domains/valuablework.com/public_html/backend/rw0586AFDA_D4F8_4D8C_B3D3_360094277A69/config.php”,“email_sent”:true} []
