Support in Images for Remote Resources
When can we expect to see support for using remote images in the Image Component. I know you could add remote images to the v1 Card Component but you could not add them to regular image components.
I don’t want to have to come back to change all of the local images to remote ones if I charge on ahead with the v2 components.
I’d also like to know when we can expect to see the v2 Card Component as I use the cards a lot and for now have created a crude version to use until it arrives.
Have bumped it up the list and will get to it sooner rather than later!
It won’t be making a comeback any time soon, we’re focusing on making the core components more flexible so these things can be built manually. If you’re struggling to recreate want you need let me know and I can build an example project for you.
Awesome.
Good to know about the Card component, it was very handy. I especially liked the fact that you could turn on and off various parts of the component.
I have built something similar, but I could use some help figuring out the right way to add a drop zone as a footer that will stay pinned to the bottom of the container.
This is what I currently have but as you can see the button is not pinned to the bottom. Plus I would like to make the button full width, but it only makes sense if it can be pinned to the bottom. I tried but I could not get the button to be pinned.
In the past I have done this by putting all of the upper elements of the container in another container and then the button below that. Then I set the content to Space Between (if I remember correctly) and that would force the button to the bottom.
Any help would be greatly appreciated as I would turn this into a global and then use it all over my site.
