SVG Stroke Transitions
I’m using beta19 I added a dropzone to a custom component, then dropped an SVG component in there, drag/dropped an svg image from resources to the image drop well on the right. Then double-clicked on svg in edit window to get the svg editing controls. I set Stroke > Hover to different start & end colors. I then set Transitions to ‘All’, Ease-in-out’, ‘1000’ and ‘0’ This should give a nice slow transition, but stroke is instant. Can stroke have a transition?
Ah yes, I’ll add this to the list to take a look at!
Hey @Bill Your wish is my command :magic_wand:
The next beta (Beta 21), adds opacity and transition effects on stroke :boom:
Hopefully, on FILL as well, right?
Yes, works on Fill as well :smiley:
