Tabbed Content Work around
I have quite a few pages on a website I’m rebuilding that has tabbed content. I know as of now Elements doesn’t have anything like that built in so I’m looking for ideas that would serve as an alternitive. I’m thinking possibly a Model.
RJ
@Dan or @Ben made a video of importing Tailwind ‘stuff’ like this;
Would that help?
@ajenks I’d 100% recommend a Custom Component! ChatGPT5 really shines at this stuff…
Do you have an example of what you’re trying to create? How many tabs do you need?
Thanks Russ, I will check that out.
Thanks Dan for the recommendation, I will do some experimenting with chatGPT and Claude, honestly for some of the pages the tabs are overkill so I think I can eliminate some of them all together.
FYI I copied the code using the top right icon
Created a new HTML component
Opened the code editor and dropped the code in.
It gives me;
Screenshot 2025-08-13 at 15.16.34
