Tables beta 3
Yes mine did that then I was able to edit the empty cell strange random
just opened with blank cell in table edit text below, able to edit blank cell who knows
David “to fail is to succeed” but “it’s cheaper to learn by others” So you are not moaning in any way shape or form. You have “failed” in attempt to do something, you’ve been brave to say that you have “failed”. So now the fix will be done (notice the power of the force) and we will ALL benefit! So pat yourself on the back and keep “moaning” we love it!
I had 2 blanks cels with a populated cell in the middle..tried to edit the bottom empty cell and the top one edited hahahaha
same here but had to click somewhere else in the cell, saved and reopened, kind of works but seems to jump to cells, double or single click to get into cell
at the moment all I can say is….DONT MAKE A MISTAKE hahahaha
With effort you can get back into cells, no more checking for me.
We are the UAT
I dont think its consistent tho…1 time it works another not so… and to say this topic is solved is not correct either
Shows you’re not an AI Bot then! :rofl::rofl::rofl::rofl::rofl::rofl:
sometimes I wish I was hahaa
and if you create a table and forget to put a row in half way down…good luck trying to insert an extra row in the middle hahahahaha
So no insert above or below
nope
I have a table here but its html and just a bit fiddly to enter data..was hoping this tables component would make it easier..
dan done this for me way back when
but at least you can add or remove columns and rows
Remember this is a beta… and this is not excel, so it’s not going to be a “fully featured” spreadsheet application…
Anyway, we’ll have a new build out later today :crossed_fingers: that should allow you to edit those empty cells :slight_smile:
