Hi, I just started a new project using Elements. While setting up the theme studio, I noticed it has tabs (menu, view, show tab bar). However, if you add a new tab, it seems to open e new project page in the theme studio. That seems counter-intuitive. Is that a bug or a feature?
Best, Matthias
Oh that’s a bug. You can create new tabs in the main projects window, to create new projects, but you shouldn’t be able to do that in the Theme Studio ![]()
We’ll get that fixed!
@dan Oh, wait, I thought that was a feature.
I use this all the time if I have two projects open I can open the theme studio in both of them. Their settings then appear in tabs within the studio making it a lot easier to compare settings from one project to another. Or to copy settings from one to another.
No, there’s a bug where you can open a document in the theme projects window ![]()
However if you have multiple documents open, you can still have tabs in the theme studio, this is okay ![]()
It might be a stupid question but how do you add extra tabs to the Theme Studio?
It’s a macOS thing, so I’m not 100% sure on the settings… did you try restarting Elements?
No, but I did notice you are suing a Pro license. Is that the issue as I am on Plus?
No, it’s a macOS thing. Will dig into it later and find out what macOS setting to enable to get the + icon.
A quick google will probably give you the answer!
