Tailwind 4 - shading
I am using the new added features for shading that come with TW4 and I want to do the following. I know I can make a custom component and add HTML Code but wanted to know if I can just do this with the new controls, but I am struggling. Is it possible to do two spheres like below. I have a circle and I have dded shadings and played with controls but not getting it. TIA @dan @upssjw
@PMUK Elements only
First one even has shadow on bottom, missing strong light at top
Second one nearly got there
the components need a couple of extra controls, 3D transform as well, then they would be phenomenal, same for Reveal as well
Phenomenal as always, can I have a clue as how you got there as mine look crap! :slight_smile: :slight_smile: :slight_smile:
@PMUK
I had to add two components together for both examples, quick, dirty but easy -
Amaze balls or is that Spheres? THANKS as ALWAYS you are a STAR!!!
no probs, probably easier to do than this
Elements components only see video above
ok doubled size of spheres, adjusted angle of shadow on first sphere, tried to create illusion second sphere, bowl is in sphere
could probably add a small circle to create highlight but couldn’t be bothered
quick, dirty but easy, probably different ways to do this
leave until tomorrow morning if anyone is interested
elementsapp://downloadDocument/c1F8Ggwa2HyQ
