Tailwind simple scroll any content
a little obsessed with CMS so simple, here 5 lines of tailwind, dropped in cms background then just the text component (not cms), could just be flex grid container etc. I’ll add a couple of controls and paste a little clunky code (been deleting adding to try different things) can be vertical at this stage and manual, but will improve over time. trying too use little code and let Elements do the heavy lifting
had 5 mins edit mode easier that when they were against each other different ways to do this, add bg color control
added extra controls, still need to fix a centering position
a quick update
warning this is not finished, I am still playing with this, it may not work where I have not tested, there are a couple of annoying things I need to fix, need to sort out position of scroll bar(z-index)
for my needs this works
scroll box needs to be in scroller, content has to be in a scroll box
all the controls have not been added
feel free to use but no help given
ok here is project - elementsapp://downloadDocument/eoCYyDParCpP
image slider works in manual slider
forgot about this addicted to twig/cms, thought I would add arrows (still in progress), try to replicate a websites scroll
Free component once Store is up and running
ok will add 3d view for scroll item,s this was for something else so will adjust origin
maybe auto scroll? option
auto scroll option - full screen bonus, my speed calcs are a little out
Those 3D cards look very cool, nice work!
@dan this was just an exercise for something else, so if anyone wants to try creating,
component in project
turn off spin and travel you have a card
project - elementsapp://downloadDocument/MVTr0eEJ2ai0
also when I set controls not to show changes they still highlight
what can you do in Elements with no code and a little code, just for fun, before breakfast and off to work
Tailwind snap https://tailwindcss.com/docs/scroll-snap-type#horizontal-scroll-snapping
Oh, that is very cool with the snap class, not sure I’ve ever used that :exploding_head:
vertical scroll, no scroll bar in first example
free project - elementsapp://downloadDocument/klZ7c9tU14j5
