Text Entry Slow
Whenever I enter text into any component, the text entry happens in slow motion (I type in the word and it appears slowly one letter at a time). Is this a problem unique to my machine or is there something I should be looking at on my end? I have an iMac with the M1 chip running Sonoma 14.6.1
It seems to occur mostly when entering or editing text in my footer grid.
Thanks.
Jeff
That’s not expected behaviour, it should feel like just writing normal in a text field.
Can you share your project via Elements Cloud and we can look into what might be causing the issue for you!
I have the same issue, but only when I change text in a text component or button component that is set as a “global.” I notice this especially on larger pages.
Sure, do you want me to send you the link via text message?
I have experienced this too, also on probably my ‘heaviest’ page.
Sounds like things can get a little slow on large pages that use on Globals. I’ve created a ticket to look into this and improve performance!
@dan Do you need a project file, or do you already have a larger one to test with?
If you have one that’s particularly bad, please do send it over to: forumsupport@realmacsoftware.com
