Is there a way to make a text snippet? I use a few text strings often. I have them as clippings on my desktop right now, but having them inside Elements would be helpful.
Try TypeIt4Me. Basically you create an abbreviation for the text snippet you want expanded, then type abbreviation\ and it’s substituted. Works great for things you type a lot.
@thominator I have Keyboard Maestro which has the same ability, and I will consider using that. It would be nice to have text snippets as a part of Elements.
