Transform Props z-index
not sure if thats possible, but a z-index would be nice in the transform. Since when the scaling goes to much up it might overlay and that depends then on the order.
And yeah it is possible with the CSS classes. So I got a solution. It might be just more intiutive to have that in the dialog.
While it’s not with the Transform settings… you can set the Z-Index under the layout Tab… does that work for you?
Hi @Dan,
that wont work since I need a change when its “Transforming”. Like scale up.
If you have an image thats scales bigger on hover it has to be above all other onces.
But yeah the CSS Classes would work. Just a suggestion if you guys are doing animations it might be required and not so clear for new users or someone who is not familiar with tailwind how to achieve that.
