I found the password protect component installed twice, one of them in trial mode. Not sure is correct.
Uninstalling the trial removes both.
the “buy” button is still enabled too.
Can you try logging out and logging back into Elements Cloud to see if that resolves the issue for you?
today I opened the store and all was fine ![]()
Ah, perfect!
