Tutorial or help with building a email contact page
I need help building a basic contact page in elements where the person can fill out a form and send me an email. I’d like to build one but if there is a shortcut or a drag I can do that too. I tried searching for a tutorial but can’t find one.
If you go to the Templates panel and look under the Core templates, you will find a couple of contact templates that you can drag into your page. Otherwise, the next best bet is one of the sample projects, like NorthEleven.
Thank you. I found the contact form and it’s perfect. Just trying to find out where to click to put my email address.
If you look in the node tree you will see a Form component, if you select it you will see all of the form properties where your info can be entered.
