I’m having trouble with canonical tags. On a main page of a website I’m getting two canonical tags. The first one is controlled by the canonical url in the meta tags section and located just before the keywords meta name in the head. The second one, which I can’t seem to modify is located after the og metatags in the head. How do I fix this? Maybe a bug?
Is it possible that you made changes under Project Settings → Template?
At first glance, that would be the only thing I can think of that might be causing this. In that case, you should try resetting everything by clicking “Revert to Default” and then republish your entire project.
The only things I can think if is it’s a left over from a previous version of RW and subsequent versions are not cleaning it up?? None of the other websites I look after have this issue.
I figured it out. I had an extra tag set up Page Settings → Edit Extra Code? I must have done this prior to the canonical tag being added to the Page Settings page.
