Typed and recommendation for a HTML writer
I have used Typed from Relamac for years but just got this app may not be updated - Apple Intel notice. If this is correct anyone got a good app they’re using for writing code? @dan TIA
BBEdit. It’s free. :free_button: :slightly_smiling_face:
is Typed finished then?
Hi @PMUK,
Can you confirm if you’re still using the Typed app and never moved over to Focused?
Tom youre correct i did move over to Focused - just checked and you sent me my long in code years ago. Sadly it doesnt work now thats why I was using typed. The icons are familiar.
Tom tried code you gave me this morning and got this.
Can you check the version you have, it should be Focused Version 3.6 (1853). You can download it here Focused - Distraction-free markdown editor for Mac · 71Squared
Also make sure you’re not running any firewall software like little snitch that could be blocking the activation system.
1.4 but been on relic site and can’t find where to update it. Do you have a link please and thanks!
Hi @PMUK,
The current build is here: Focused - Distraction-free markdown editor for Mac · 71Squared
You want Focused 3.6 (1853). Version 1.4 is the old one, so that activation error is expected. Download that, then try the code again.
And as if by magic I am now FOCUSED agin. THANKD Tom as always have a great day!
